Custom tool for tags creation
Hi all
My customer would like to create Tags without using Ignition Designer. Is there any endpoint to connect to for Tags creation from outside? Or a tool like gcu, that could get a CSV file in and create gateway Tags accordingly?
Thanks in Advance, regards
Yes, they can do this from vision (definitely, have done it) client, probably perspective (with a bit more work due to file access restrictions).
Open the CSV file. Parse it. Script with Jython to create the new tags.
# This example will add a new OPC Tag. It can be further expanded to modify more
# properties on the Tag. Additionally, this example can be used to edit an existing Tag
# by setting the baseTagPath to a Tag that already exists, and by modifying the collision policy.
# The provider and folder the Tag will be placed at.
baseTagPath = "[default]MyFolder"
# Properties that will be configured on that Tag.
tagName = "myNewTag"
opcItemPath = "ns=1;s=[Simulator]_Meta:Sine/Sine0"
opcServer = "Ignition OPC-UA Server"
valueSource = "opc"
sampleMode = "TagGroup"
tagGroup = "Default"
# Configure the tag.
tag = {
            "name": tagName,
            "opcItemPath" : opcItemPath,
            "opcServer": opcServer,
            "valueSource": valueSource,
            "sampleMode" : sampleMode,
            "tagGroup" : tagGroup
# Set the collision policy to Abort. Thus, if a Tag already exists at the base path,
# we will not override the Tag. If you are overwriting an existing Tag, then set this to "o".
collisionPolicy = "a"
# Create the Tag.
system.tag.configure(baseTagPath, [tag], collisionPolicy)
https://docs.inductiveautomation.com/display/DOC81/system.tag
https://docs.inductiveautomation.com/display/DOC81/system.tag.configure
No.
Everything is supposed to be an API when 8.3 comes out, though.
In addition to a dedicated Vision or Perspective solution, you could also use WebDev to create an API.
Hi @Matrix_Engineering, thanks for your suggestion: I know I could, but I was wandering if there were anything ready to go.
Hi @pturmel , that sounds very good! Will that mean that through RESTful webservices calls it will be possible to configure some or any gateway/project parameters?
Thanks, regards
That's what Carl said at ICC this year.
Very nice, thanks @pturmel
