I don’t know if you found a solution to this, but for posterity, this is what I have used before. I don’t know if there’s an easier way… Definitely open to suggestions!
This gets the next tank in a list of tanks, and cycles around to the beginning if at the end.
--Gets the next tank. If we're at the last tank, then returns the first tank
SELECT TOP 1 MIN(TankNumber) as TankNumber, MIN(TankPrefix) as TankPrefix, MIN(TankFarm) as TankFarm FROM (
SELECT TankNumber, 'A' as SORT, TankPrefix, TankFarm
FROM cfgTanks
WHERE TankNumber > {Tank Navigation.TankNumber} AND TankFarm = '{Tank Navigation.TankFarm}'
UNION ALL
SELECT TankNumber, 'B' AS SORT, TankPrefix, TankFarm
FROM cfgTanks
WHERE TankNumber = (SELECT MIN(TankNumber) FROM cfgTanks WHERE TankFarm = '{Tank Navigation.TankFarm}')
) C
GROUP BY SORT
ORDER BY SORT ASC
And this is to get the previous tank:
--Gets the previous tank. If we're at the first tank, then returns the last tank
SELECT TOP 1 MAX(TankNumber) as TankNumber, MAX(TankPrefix) as TankPrefix, MAX(TankFarm) as TankFarm FROM (
FROM cfgTanks
WHERE TankNumber < {Tank Navigation.TankNumber} AND TankFarm = '{Tank Navigation.TankFarm}'
UNION ALL
FROM cfgTanks
WHERE TankNumber = (SELECT MAX(TankNumber) FROM cfgTanks WHERE TankFarm = '{Tank Navigation.TankFarm}')
) C
GROUP BY SORT
ORDER BY SORT ASC
