Hi
Tag import does not work when having cyrillic fonts in csv file.
Is there any way to make this work or do we have to write these in manually in tags?
Br
Tommi Vahtera
THT Control Oy
Hi
Br
Tommi Vahtera
THT Control Oy
Unfortunately they have to be entered manually at this time.
The problem has to do with the import/export functions dealing explicitly with ASCII character set encoding which can't represent the Cyrillic character set.
We are aware of the issue and are looking into it.
This has been fixed (hopefully) in 7.1.8. Basically, we’ve improved unicode support in tag export/import, so you shouldn’t have a problem.
Regards,
Thanks, I will test in 7.18 and reply results here.
Br
Tommi Vahtera
Hi Tommi-
Just to be clear, it will be in beta 4 which isn’t up yet- but should be in a bit.
Regards,
