Dashboard background image style settings
I’m away from my home computer at the moment so I’ll have to attach more details screenshots later.
However, I was curious how I can get a background image on a dashboard component to stay aligned with the widgets grid. So for instance if I zoom, it’ll zoom in the background image instead of zooming in the widgets and resizing the background image. I played around with a few different ways but was unsuccessful and was curious if maybe if someone else has had any luck doing something similar?
The end goal is that I have tabletop ‘map’ with known row/column count and every interact-able space within the grid will be an individual ‘widget’. I had limited success with it not zoomed in but some weird cropping of the background image that wasn’t there in the source was throwing off my count.
Pretty sure you'll have to use a pan and zoom container for this, but I could be wrong. The only option at the moment that is out* is BIJC's module which we're using at the moment for displaying p&ids on mobile. It may not have the flexibility you need though for a dashboard..
*there are 2 other companies developing this that I know of, one free and another paid
Edit: you might be able to use the background-size CSS prop to do this better as well. Try setting it to cover or maybe setting it to a fixed width will work? Eg 100vw
Completely untested
