Dashboard Component Custom Widget Selector
I am working with the Perspective Dashboard component. As is, when in edit mode, if the use clicks on a cell, a built-in widget selector pops up automatically. I would like to be able to bypass that widget selector and have it instead popup my own custom widget selector.
Is there a way to prevent the built-in popup and have it pass that selected cell info to my own selector?
No, there is no way to configure your own Widget selector.
Even use of fancy CSS to "hide" the Widget Selector (incredibly dangerous because the required selector is very the very generic and widely-used div div.ia_componentModal) and modal overlay still leaves you in a state where you'd have to make use of the isEditing property to trigger a Popup of your own design - but even that would have no insight into the cell the user has selected. If you're willing to have the user select a location of their own through the Popup you could send a message to the Dashboard component, where it adds a widget based on your information in the sent message to the widgets list, but you run the risk of bypassing the inherent prevention of placing a widget at an occupied location.
TLDR: It's non-trivial and likely to break other parts of your project.
It's been awhile since this post. Checking in to see if the dashboard component has since been extended to allow for a custom widget selector? The built-in selector is probably the worst part of the dashboard component and we are using dashboarding more and more throughout our application.
As a comparison, here is the dashboard widget selector built into ClickUp.
There is a feature request for this item on the official board, but not a lot of votes yet:
Related feature request:
My guess is that the second one is more likely to get picked up as a feature as it's a lot less likely to break things but if there's enough demand for it you never know.
Thanks. Just voted for them both.
