In the below status chart, under data sources, there are series0, series 1, unlike other charts where only example prop will be there for data binding…here I am confused that where to bind the dataset …plz help … @victordcq @pascal.fragnoud @cmallonee @paul-griffith
image|690x140
The screengrab you have posted looks like you are working with Perspective (but you haven’t tagged your post with the ‘perspective’ tag). Perspective doesn’t have a ‘Status Chart’ component so it is not clear what component you are using.
Please edit your question to improve it and remove the @username pings . People will answer a well written question if they are interested. Being targeted like that will probably put them off.
ok noted…
Thank u
