Is there a perspective component or a way for an ignition user to add, delete, change values or rows in SQL? Sometimes our line operators might double enter a transaction or might select a wrong entry which gets recorded. I have perspective table pulling last 50 records from a named query, but I am not sure how to use a update query and make one of the cells editable without making another dataset and table. I would like to change the last record Actual=51 to Actual=52.
This will work, but the code is for Vision-Power Table. Editing Multi-Selected Rows from a Table - Ignition User Manual 8.1 - Ignition Documentation (inductiveautomation.com)
