Hi All. I have been working with a data source that stores data in batches of 1 minute. using the OPC client interface, this works fine for tags with a scan interval of 1 minute. However, when I try to collect information on tags that have a higher collection frequency like 5 seconds, I am missing all the data and only seeing the most current value appear. Which I guess is as expected. Has anyone come across a similar situation or has worked with an Ignition interface that will use OPC HDA to capture data over a set window (in batches) so that am not losing information from tags with scan frequencies of less than a minute.
Really making use of Ignition as a data interface so that we can that forward and aggregate information into the cloud. At the moment, Ignition is capturing a value everytime the source system identifies a change. the problem occurs when the source system identifies a block of changes that are written all at the same time and so ignition is only capturing the one value rather than the block of values.
