Data Filter Prior to Storing in Historian or Publishing to Cloud
Hello,
I am trying to think of a way to clean/filter noise from tag data prior to storing it in Historian or Publishing to the cloud. Any suggestions?
If you can’t clean/filter the data at the source, you could use an expression tag in Ignition to do the filtering and historicize the expression tag rather than the raw tag.
I am also facing this problem, I was planning to use this script:
if(value != 0,  value, value)
but I found out, I can't know what the last data was like, what should I write for this filtering script?
