Folks,
I thought I would put this one out there to get any advice and help I can from peoples vast experience before I tackle this little and probably simple task.
To set the scene;
I have two PLC’s controlling different machines. Im going to pull data from both machines to create PDF reports and save them.
I have PLC tags from when to save etc.
I want to store 5 minutes of data (per second) pulled from 12 REAL values and store them in a data base from machine A
I want to store around 10 REAL values pulled from machine B after it has complete its cycle from machine B
I then want them to be pulled pulled into a report then saved with either a job number or date/time stamp.
Once its been saved then I want the whole process to start over again with in incrementing job number or time stamp for the saved file.
This will happen probably every 15-20 minutes.
Sometimes the Job might be skipped so the operator will press a button on the screen saying failed. I do this to keep the job counter incrementing. So in this instance the report will still be created but it will be labeled as a failure.
Every day I would like to create a new folder for the stored PDF’s to keep them easy to access, or would it be better to keep adding pages to the PDF for that day ?
I already have logging set up on the siemens PLC’s and HMI’s but they only log as CSV files and because there is two machines it creates two separate files. Im going down this road to create a PDF containing both values. Creating all the tags isn’t a problem, having data store to the data base shouldn’t be a problem. But having the data base overwritten after every job is something I have to learn, as is creating and saving the report for every job based on the incrementing job number.
Anyone done anything similar before in making PDF reports of this frequency and has some words of wisdom
Thankyou.
