Data Missing to log to database
Hi all,
After joining our SCADA PC to the company domain, we randomly lose a complete 10-second history timestamp for all tags. It worked fine in a workgroup.
Setup:
1.Ignition and the database are on the same physical PC
2.Logging interval: 10 s
3.The only change is workgroup → domain. No policies have been applied yet.
Problem
A full timestamp is missing for all tags. For example, we get a row at 1:00:00, then the next at 1:00:30 instead of 1:00:20. The problem started the moment the PC joined the domain.
What we've checked:
1.Antivirus is not a suspect, because the same software ran fine in the workgroup.
2 To rule out the gateway-to-DB connection, we disconnected the DB. Store & Forward cached the data, but that timestamp is still missing.
So the data seems to be lost before it reaches the DB or Store & Forward, not during the DB write.
Question
What changes when a PC joins a domain that could make Ignition skip a whole logging cycle? What should we check on the Windows or Ignition side?
Thanks!
Sigh. You may find some corner case to explain this. But this kind of foolishness is another red mark against Windows and its ecosystem.
The correct solution is to not use Windows in production systems. Full stop.
IMNSHO, using Windows in production systems is engineering malpractice.
I don’t know why it would be domain related, but this sure sounds like issues I’ve had with redundancy and firewalls in the past.
Could there be some sort of redundancy “event” that is causing a network device to do something with STP or ARP?
I would be investigating packets near the same time as the missing data.
Note: Domain redundancy, not Ignition redundancy.
