Data points Overlap in XY chart - 8.0.15
IGNITION - PERSPECTIVE
1.How to avoid Datapoints Overlap in XY Chart when we need to visualize the data for longer date range
2. How to configure the dates in X axis without skipping the date sequence
Show us the dataSources that are being used to generate the chart.
  • In Property Editor, right-click on dataSources.
  • Copy.
  • Paste in here.
  • Format it using the </> button on the editor toolbar.
  • Preview before posting.
Apologies for the confusion. Please refer the formatted text below and do the needful
Preformatted text[
"type": "ia.chart.xy",
"version": 0,
"props": {
"title": {
"text": "Day - Energy",
"appearance": {
"color": "#000000"
"subtitle": {
"appearance": {
"color": "#000000"
"legend": {
"position": "right",
"absolute": {
"x": 10,
"y": 10
"markers": {
"stroke": {
"color": "#D5D5D5"
"icon": {
"color": "#D5D5D5",
"horizontalCenter": "none"
"labels": {
"font": {
"weight": 500,
"size": 9,
"color": "#000000"
"enableTransitions": true,
"scrollBars": {
"horizontal": {
"enabled": false
"vertical": {
"enabled": false
"xAxes": [
"name": "time",
"label": {
"enabled": false,
"text": "Time",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "date",
"category": {
"break": {
"enabled": false,
"startCategory": "",
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": true,
"timeUnit": "hour",
"count": 1,
"skipEmptyPeriods": false
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "M/d/yyyy",
"format": "M/d"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"logarithmic": false,
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###.##"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "#2B2B2B",
"opacity": 1
"grid": {
"color": "",
"opacity": 0,
"dashArray": "",
"minDistance": 60,
"position": 0.5
"font": {
"size": 10,
"weight": 1000
"yAxes": [
"name": "kwh",
"label": {
"enabled": true,
"text": "kWh",
"color": "#000000"
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "value",
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy-MM-dd kk:mm:ss",
"format": "M/d/yyyy HH:mm:ss"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "#2B2B2B",
"opacity": 1
"grid": {
"color": "",
"opacity": 0,
"dashArray": "",
"minDistance": null,
"position": 0.5
"font": {
"size": 10,
"weight": 1000
"series": [
"name": "s1",
"label": {
"text": "shift1"
"visible": true,
"hiddenInLegend": false,
"defaultState": {
"visible": true
"data": {
"source": "example",
"x": "time",
"y": "s1"
"xAxis": "time",
"yAxis": "kwh",
"zIndex": 0,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{valueY}[/]\nDate:[bold]{dateX}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "column",
"candlestick": {
"open": {
"x": "",
"y": ""
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"deriveFieldsFromData": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#D6D614",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": true,
"width": null,
"height": null,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"line": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": false,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{valueY}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"stepLine": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"candlestick": {
"appearance": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": "",
"min": ""
"stacked": false,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"open": {
"x": "",
"y": ""
"column": {
"appearance": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"fill": {
"color": "#3366CC",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": "",
"min": ""
"height": null,
"stacked": true,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"width": null
"open": {
"x": "",
"y": ""
"data": {
"x": "time",
"y": "s2"
"defaultState": {
"visible": true
"label": {
"text": "shift2"
"line": {
"appearance": {
"bullets": [
"fill": {
"color": "",
"opacity": ""
"rotation": "",
"stroke": {
"color": "",
"opacity": "",
"width": ""
"enabled": false,
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": 100,
"min": 2
"height": 10,
"label": {
"position": {
"dx": 0,
"dy": 0
"text": "{value}"
"render": "circle",
"rotation": 0,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"width": 10
"connect": true,
"fill": {
"color": "",
"opacity": 0
"minDistance": 0.5,
"stroke": {
"color": "",
"dashArray": "",
"opacity": 1,
"width": 3
"tensionX": 1,
"tensionY": 1
"open": {
"x": "",
"y": ""
"name": "s2",
"render": "column",
"stepLine": {
"appearance": {
"bullets": [
"fill": {
"color": "",
"opacity": ""
"rotation": "",
"stroke": {
"color": "",
"opacity": "",
"width": ""
"enabled": true,
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": 100,
"min": 2
"height": 10,
"label": {
"position": {
"dx": 0,
"dy": 0
"text": "{value}"
"render": "circle",
"rotation": 0,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"width": 10
"connect": true,
"fill": {
"color": "",
"opacity": 0
"minDistance": 0.5,
"stroke": {
"color": "",
"dashArray": "",
"opacity": 1,
"width": 3
"tensionX": 1,
"tensionY": 1
"open": {
"x": "",
"y": ""
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"visible": true,
"xAxis": "time",
"yAxis": "kwh",
"zIndex": 0
"candlestick": {
"appearance": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": "",
"min": ""
"stacked": false,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"open": {
"x": "",
"y": ""
"column": {
"appearance": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"fill": {
"color": "#4FC86C",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": "",
"min": ""
"height": null,
"stacked": true,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"width": null
"open": {
"x": "",
"y": ""
"data": {
"x": "time",
"y": "s3"
"defaultState": {
"visible": true
"label": {
"text": "shift3"
"line": {
"appearance": {
"bullets": [
"fill": {
"color": "",
"opacity": ""
"rotation": "",
"stroke": {
"color": "",
"opacity": "",
"width": ""
"enabled": false,
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": 100,
"min": 2
"height": 10,
"label": {
"position": {
"dx": 0,
"dy": 0
"text": "{value}"
"render": "circle",
"rotation": 0,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"width": 10
"connect": true,
"fill": {
"color": "",
"opacity": 0
"minDistance": 0.5,
"stroke": {
"color": "",
"dashArray": "",
"opacity": 1,
"width": 3
"tensionX": 1,
"tensionY": 1
"open": {
"x": "",
"y": ""
"name": "s3",
"render": "column",
"stepLine": {
"appearance": {
"bullets": [
"fill": {
"color": "",
"opacity": ""
"rotation": "",
"stroke": {
"color": "",
"opacity": "",
"width": ""
"enabled": true,
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": 100,
"min": 2
"height": 10,
"label": {
"position": {
"dx": 0,
"dy": 0
"text": "{value}"
"render": "circle",
"rotation": 0,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"width": 10
"connect": true,
"fill": {
"color": "",
"opacity": 0
"minDistance": 0.5,
"stroke": {
"color": "",
"dashArray": "",
"opacity": 1,
"width": 3
"tensionX": 1,
"tensionY": 1
"open": {
"x": "",
"y": ""
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"visible": true,
"xAxis": "time",
"yAxis": "kwh",
"zIndex": 0
"style": {
"backgroundColor": "#CCCCFF",
"color": "#000000",
"fontFamily": "Arial",
"fontSize": 15,
"fontWeight": "bold",
"textAlign": "start"
"dataSources": {}
"meta": {
"visible": false,
"name": "XYChart"
"position": {
"x": 19.85930000000002,
"y": 8.7747,
"height": 265,
"width": 740
"custom": {},
"propConfig": {
"props.dataSources.example": {
"binding": {
"type": "query",
"config": {
"queryPath": "Shift_Final",
"parameters": {
"st": "dateArithmetic({.../DateTimeInput.props.value}, -6, "days")",
"ln": "{.../Line_Dropdown.props.value}",
"ma": "{.../Machine_Dropdown.props.value}",
"bg": "{.../BG_Dropdown.props.value}",
"pl": "{.../Plant_Dropdown.props.value}",
"sp": "dateArithmetic({.../DateTimeInput.props.value}, 1, "days")"
The data looks OK (although you didn't manage to format it). The format button works the same as any other formatting button such as Bold or Italics: select the text then press the button.
We'll need to see how you've configured the XY Chart.
  • In Project Browser, right-click on the XY Chart.
  • Select Copy.
  • Paste it in here.
  • Select all the code and format it using the </> button on the editor toolbar.
  • Preview before posting and fix it if it's wrong. It should look like this:
    "version": 0,
    "props": {
      "xAxes": [
          "name": "time",
          "label": {
            "enabled": true,
            "text": "Time",
            "color": ""
          "visible": true,
        etc. ...
{ Please follow @Transistor 's instructions. The most helpful people around here are unlikely to help you if you don't help them by clearly formatting your posts. Visible indentation is vital information, and your post doesn't have it. Click the "pencil" icon to edit your post and follow instructions. }
Apologies for the confusion. I have updated the formatted text above as per the instructions. kindly refer and give suggestions
It is not formatted. It still shows no indentation. Select your json/python/log text/whatever then click the "Preformatted Text" button.
Quick question:
Does this look formatted to you?
compared to @Transistor 's
(If you get RSI when scrolling to reach the bottom of your own single post, then you've probably not formatted it right)
Again Apologies for the confusion I hope the below text will be in correct format
  1. In that txt I need to know what parameters i need to pass for st and sp inorder to get the output for current date and previous 6 days value. kindly give suggestions regarding all parameters
    "version": 0,
    "props": {
      "title": {
        "text": "Day Energy (in kWh)",
        "appearance": {
          "color": "#000000"
      "legend": {
        "markers": {
          "width": 10,
          "height": 3
      "cursor": {
        "lineX": {
          "stroke": {
            "width": 0.5
      "background": {
        "gradient": {
          "rotation": 90
      "xAxes": [
          "name": "time",
          "label": {
            "enabled": true,
            "text": "Date",
            "color": "#000000"
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": true,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "day",
              "count": 1,
              "skipEmptyPeriods": true
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "dd-MM-yy"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "#000000",
              "opacity": 1
            "grid": {
              "color": "",
              "opacity": 0,
              "dashArray": "",
              "minDistance": 50,
              "position": 0.5
            "font": {
              "size": 15,
              "weight": 700
      "yAxes": [
          "name": "Diff",
          "label": {
            "enabled": true,
            "text": "kWh",
            "color": "#000000"
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "value",
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "day",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "HH:mm:ss"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "#000000",
              "opacity": 1
            "grid": {
              "color": "",
              "opacity": 0,
              "dashArray": "",
              "position": 0.5
            "font": {
              "size": 15,
              "weight": 700
      "series": [
          "name": "Diff",
          "label": {
            "text": "kWh"
          "visible": true,
          "defaultState": {
            "visible": true
          "data": {
            "x": "time",
            "y": "Diff"
          "xAxis": "time",
          "yAxis": "Diff",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "{name}: [bold]{valueY}[/]\n Date:[bold]{dateX}[/]",
            "cornerRadius": 1,
            "pointerLength": 1,
            "background": {
              "color": "",
              "opacity": 1
          "render": "column",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "#8A8AFF",
                "opacity": 1
              "stroke": {
                "color": "#555555",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "#0000FF",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": -5
                  "fill": {
                    "color": "#2B2B2B",
                    "opacity": 1
                  "stroke": {
                    "color": "#47FFFF",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
      "dataSources": {}
    "meta": {
      "name": "XYChart_0"
    "position": {
      "x": 19.6539,
      "y": 15.559200000000004,
      "height": 263,
      "width": 722
    "custom": {},
    "propConfig": {
        "binding": {
          "type": "query",
          "config": {
            "queryPath": "DayEnergy",
            "parameters": {
              "ll": "{.../Line_Dropdown.props.value}",
              "st": "dateArithmetic({.../DateTimeInput.props.value}, -6, \"days\")",
              "sp": "dateArithmetic({.../DateTimeInput.props.value}, 0, \"days\")"
  }`Preformatted text`
type or paste code here
````Preformatted text``Preformatted text``Preformatted text``Preformatted text
I'm having a look, but for others, watch out for this "Preformatted text" landmine:
You'll need to disable the binding on dataSource.example, as we don't have your SQL data and the named query, hence the data is blank when we import it.
This is unrelated, but it seems like you've added this into a Coordinate View or container. I don't know your page design, but generally if it's got a chart on it like this, 9 times out of 10 it should be in a Flex View, not a Coordinate View so that it resizes nicely and is easy to develop and maintain
Thanks for the suggestions.
I have modified the chart type from line to bar chart and modified the query,now i didnt get the datapoints overlap but i have some issues in passing the parameters to get the exact value which i expected.
kindly refer the code and give suggestion to pass the parameters for :st and :sp
I have no idea what issues you're having if you don't tell me the issues and what you're expecting to see...
But I noticed that perhaps "days" isn't valid for dateArithmetic
