Using an example code snippet from the Ignition Manual I am using a DateRange component to filter table data based on time in an SQL query, as soon as I close the script window I get an error with the query. The Details are Incorrect Syntax, can anyone help out? I’m not sure what I’m doing wrong, FYI the column that is being filtered is based off the tag var LastChange. See Below…
Put single quotes around the control values.
'{Root Container.Date Range.startDate}'
There’s probably a difference in format syntax that is causing something unexpected. Try checking what the output looks like with something like:
SELECT '{Root Container.Date Range.startDate}'
Then insert the date formatted string into our original query to see whether it’s a date format the RDBMS expects (usually, DBs will only automatically cast strings -> dates in very specific formats)
Also I see now that you are selecting on a timestamp field.
Is that an actual SQL Timestamp field or a datetime field you named that?
Actual timestamp fields aren’t designed to be used as datetime fields.
Since you have a space in the table name you will have to wrap that in quotes on your insert or brackets.
INSERT INTO [Backflow Preventer]
or
INSERT INTO 'Backflow Preventer'
I mistyped the table name, it should be Backflow_Calibration, it ended up being the format of times were mismatched I added the system.date.format to make them line up. Thank you for your time!
