I am working on a process where I am validating table returned data set with custom template data set and all the values match when debugged in designer and designed shows proper results (if changes, notifies changes, if not says no changes).
But when I run the client the debug messages still show no differences but they are treated as different and notifies in the window that there are changes.
Want to check if anyone noticed similar issue and appreciate your inputs on this
if (row['col1'] != row1['col1'] or row['col2'] != row1['col2'] or row['col3'] != row1['col3'] or and so on):
#dataset1
[5.0, 2876.0, 189201.0, Fri Jul 24 14:00:00 EDT 2020, Fri Jul 24 22:00:00 EDT 2020, Fri Jul 24 14:00:00 EDT 2020, Fri Jul 24 14:20:00 EDT 2020, None, None, None, None, None, None, None, None]
#dataset2
PS: I am using == and != comparisions for None checks too and as I mentioned everything evaluates properly in designer
