Data Sharing Between Tabs
I have a tab strip(3 tabs) that contains a date component and a dropdown list for each tab. When I click the values for these three items in any one tab, I need to automatically replicate these values to the other two tabs until I log out of the session. I have tried using session properties for this logic, but I am facing an issue where the data becomes null when I move to another tab.
Perspective doesn't have a "tab strip" component. Maybe you have a Tab Container view or a Tab Container component inside some other type of view. You can edit your original post to clarify.
Some properties can be made persistent so check that to see if you've missed something.
https://docs.inductiveautomation.com/display/DOC81/Perspective+Component+Properties#PerspectiveComponentProperties-PersistentProperties
