Database connection faults when using IP instead of locahost
When I create a connection to a local database using “jdbc:postgresql://localhost:5432/postgres”, it connects with no issues. However, when I use the IP of the local computer like “jdbc:postgresql://10.80.1.251:5432/postgres”, the connection faults.
This is the error message:
java.sql.SQLException: Cannot create PoolableConnectionFactory (FATAL: no pg_hba.conf entry for host “10.80.1.251”, user “postgres”, database “postgres”, SSL off)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2385)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2110)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1563)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:250)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:203)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1061)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:581)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: org.postgresql.util.PSQLException: FATAL: no pg_hba.conf entry for host “10.80.1.251”, user “postgres”, database “postgres”, SSL off
at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:514)
at org.postgresql.core.v3.ConnectionFactoryImpl.tryConnect(ConnectionFactoryImpl.java:141)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:192)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49)
at org.postgresql.jdbc.PgConnection.(PgConnection.java:195)
at org.postgresql.Driver.makeConnection(Driver.java:454)
at org.postgresql.Driver.connect(Driver.java:256)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:53)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:291)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2395)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2381)
… 12 more
Suppressed: org.postgresql.util.PSQLException: FATAL: no pg_hba.conf entry for host “10.80.1.251”, user “postgres”, database “postgres”, SSL off
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:201)
… 20 more
8.1.7 (b2021060314)
Azul Systems, Inc. 11.0.11
I would double check that Postgres has been configured to listen on all interfaces versus just the localhost adapter (which might be the default for security reasons).
Thank you very much. I did know I had to configure security for local access.
