Seems there may be some issues deleting database connections. Towards the bottom half of the output there are some constraint violations that seem to keep it from being deleted.:
com.inductiveautomation.ignition.gateway.web.pages.config.systemconsole.LogViewer$SerializableLoggingEvent$ClonedThrowable: Executing DELETE FROM DATASOURCES WHERE DATASOURCES_ID = ? for [DatasourceRecord 0 Deleted Dirty0]
simpleorm.sessionjdbc.SSessionJdbcHelper.flushExecuteUpdate(SSessionJdbcHelper.java:409)
simpleorm.sessionjdbc.SSessionJdbcHelper.flush(SSessionJdbcHelper.java:376)
simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:425)
simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:410)
simpleorm.sessionjdbc.SSessionJdbc.commitAndDetachDataSet(SSessionJdbc.java:353)
com.inductiveautomation.ignition.gateway.web.components.actions.DeleteRecordAction.doDelete(DeleteRecordAction.java:68)
com.inductiveautomation.ignition.gateway.web.components.actions.DeleteRecordAction.execute(DeleteRecordAction.java:143)
com.inductiveautomation.ignition.gateway.web.components.ConfirmationPanel$1.onClick(ConfirmationPanel.java:42)
org.apache.wicket.markup.html.link.Link.onLinkClicked(Link.java:224)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
org.apache.wicket.RequestCycle.steps(RequestCycle.java:1428)
org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:479)
org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:312)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
java.lang.Thread.run(Unknown Source)
com.inductiveautomation.ignition.gateway.web.pages.config.systemconsole.LogViewer$SerializableLoggingEvent$ClonedThrowable: Error sending prepstatement command through cluster.
com.inductiveautomation.ignition.gateway.localdb.ClusteredDatasource$ClusterPrepStatement.call(ClusteredDatasource.java:1164)
com.inductiveautomation.ignition.gateway.localdb.ClusteredDatasource$ClusterPrepStatement.executeUpdate(ClusteredDatasource.java:1198)
simpleorm.sessionjdbc.SSessionJdbcHelper.flushExecuteUpdate(SSessionJdbcHelper.java:407)
com.inductiveautomation.ignition.gateway.web.pages.config.systemconsole.LogViewer$SerializableLoggingEvent$ClonedThrowable: Response from 127.0.0.1:10000 is error.
com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl.sendGatheringCall(ClusterManagerImpl.java:821)
com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl.sendGatheringCall(ClusterManagerImpl.java:764)
com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl.sendCall(ClusterManagerImpl.java:842)
com.inductiveautomation.ignition.gateway.localdb.ClusteredDatasource$ClusterPrepStatement.call(ClusteredDatasource.java:1157)
com.inductiveautomation.ignition.gateway.web.pages.config.systemconsole.LogViewer$SerializableLoggingEvent$ClonedThrowable: null
com.inductiveautomation.ignition.gateway.localdb.ClusteredDatasource$PrepStatementCommand.handle(ClusteredDatasource.java:339)
com.inductiveautomation.ignition.gateway.localdb.ClusteredDatasource$Receiver.receiveCall(ClusteredDatasource.java:217)
com.inductiveautomation.ignition.gateway.cluster.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:45)
com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl$SyncCallReciever.dispatch(ClusterManagerImpl.java:1586)
com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl$SyncCallReciever.handle(ClusterManagerImpl.java:1570)
org.jgroups.blocks.MessageDispatcher.handle(MessageDispatcher.java:605)
org.jgroups.blocks.RequestCorrelator.handleRequest(RequestCorrelator.java:624)
org.jgroups.blocks.RequestCorrelator.receiveMessage(RequestCorrelator.java:533)
org.jgroups.blocks.RequestCorrelator.receive(RequestCorrelator.java:365)
org.jgroups.blocks.MessageDispatcher$ProtocolAdapter.up(MessageDispatcher.java:764)
org.jgroups.JChannel.up(JChannel.java:1265)
org.jgroups.stack.ProtocolStack.up(ProtocolStack.java:444)
org.jgroups.protocols.pbcast.STREAMING_STATE_TRANSFER.up(STREAMING_STATE_TRANSFER.java:243)
org.jgroups.protocols.pbcast.GMS.up(GMS.java:787)
org.jgroups.protocols.pbcast.STABLE.up(STABLE.java:233)
org.jgroups.protocols.pbcast.NAKACK.handleMessage(NAKACK.java:830)
org.jgroups.protocols.pbcast.NAKACK.up(NAKACK.java:693)
org.jgroups.protocols.BARRIER.up(BARRIER.java:136)
org.jgroups.protocols.Discovery.up(Discovery.java:244)
org.jgroups.protocols.TP.passMessageUp(TP.java:1266)
org.jgroups.protocols.TP.access$100(TP.java:49)
org.jgroups.protocols.TP$IncomingPacket.handleMyMessage(TP.java:1809)
org.jgroups.protocols.TP$IncomingPacket.run(TP.java:1788)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
com.inductiveautomation.ignition.gateway.web.pages.config.systemconsole.LogViewer$SerializableLoggingEvent$ClonedThrowable: integrity constraint violation: foreign key no action; FK_ALERTSTORAGEPROFILEPROPERTIES_DATASOURCE_DATASOURCE table: ALERTSTORAGEPROFILEPROPERTIES_DATASOURCE
org.hsqldb.jdbc.Util.sqlException(Util.java:200)
org.hsqldb.jdbc.JDBCPreparedStatement.fetchResult(JDBCPreparedStatement.java:4260)
org.hsqldb.jdbc.JDBCPreparedStatement.executeUpdate(JDBCPreparedStatement.java:300)
org.apache.commons.dbcp.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:102)
com.inductiveautomation.ignition.gateway.localdb.ClusteredDatasource$ClusterPrepStatement._executeUpdate(ClusteredDatasource.java:1202)
org.hsqldb.error.Error.error(Error.java:112)
org.hsqldb.StatementDML.checkCascadeDelete(StatementDML.java:788)
org.hsqldb.StatementDML.delete(StatementDML.java:666)
org.hsqldb.StatementDML.executeDeleteStatement(StatementDML.java:630)
org.hsqldb.StatementDML.getResult(StatementDML.java:165)
org.hsqldb.StatementDMQL.execute(StatementDMQL.java:198)
org.hsqldb.Session.executeCompiledStatement(Session.java:1159)
org.hsqldb.Session.executeCompiledStatement(Session.java:1376)
org.hsqldb.Session.execute(Session.java:857)
org.hsqldb.jdbc.JDBCPreparedStatement.fetchResult(JDBCPreparedStatement.java:4252)
