Database connectivity issue
Hello all, I'm facing this kind of error
java.sql.SQLException: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "The server selected protocol version TLS10 is not accepted by client preferences [TLS13, TLS12]". ClientConnectionId:44dba69c-d288-4fef-8400-a9d2c994abe8)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:656)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:534)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:253)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1096)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:587)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "The server selected protocol version TLS10 is not accepted by client preferences [TLS13, TLS12]". ClientConnectionId:44dba69c-d288-4fef-8400-a9d2c994abe8
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:3937)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1950)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:3456)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:3077)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:2919)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1787)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1229)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:357)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:103)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:652)
... 12 more
Caused by: javax.net.ssl.SSLHandshakeException: The server selected protocol version TLS10 is not accepted by client preferences [TLS13, TLS12]
at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source)
at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source)
at java.base/sun.security.ssl.ServerHello$ServerHelloConsumer.onServerHello(Unknown Source)
at java.base/sun.security.ssl.ServerHello$ServerHelloConsumer.consume(Unknown Source)
at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source)
at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1839)
... 21 more
8.1.19 (b2022072711)
Azul Systems, Inc. 11.0.15
Old SQL Server. It wants TLS1.0, which is forbidden by all major software products due to security weakness.
The right answer is to upgrade that SQL Server to a modern, secure version.
The hack is to modify your java.security file to allow the bad protocol. Plenty of topics on that here.
It sounds like you’re connecting to an ancient version of SQL Server that doesn’t support at least TLS 1.2.
See Error connection SQL Server database after upgrade Ignition - #2 by Kevin.Herron and https://support.inductiveautomation.com/hc/en-us/articles/4417310204813-TLS-v1-0-and-v1-1-Microsoft-SQL-Server-Database-connection-issue
