I have two different tables I am using in a Work Order System. I am Inserting into the parent table (EquipWorkOrder) and then using a select statement to get that ID using Top 1. Then I insert that ID with UserNm and Hrs into the child table(EquipWorkOrderHrs). The problem is when more than one client inserts at the same time. It will add the wrong users to the wrong work orders and It also skips EquipWorkOrderID numbers. I believe the issue is coming from using Top 1 but I am not sure on away to fix the issue.
#insert in to EquipWorkOrder table
query = "INSERT INTO EquipWorkOrder(DateTm,PlantLocID,StatusID,MaintLocationID,EquipmentID,EquipTypeID,CategoryID,CrewID,MeterReading,Description,Resolution,Comments) VALUES(?,?,?,?,?,?,?,?,?,?,?,?)"
args = [event.source.parent.getComponent('DateTm').date,1,event.source.parent.getComponent('Status').selectedValue,event.source.parent.getComponent('MaintLocation').selectedValue,event.source.parent.getComponent('Equipment').selectedValue,event.source.parent.getComponent('EquipTypeID').intValue,event.source.parent.getComponent('Category').selectedValue,event.source.parent.getComponent('Crew').selectedValue,event.source.parent.getComponent('Meter Reading').floatValue,event.source.parent.getComponent('Description').text,event.source.parent.getComponent('Resolution').text,event.source.parent.getComponent('Comments').text]
system.db.runPrepUpdate(query, args)
#select to read last inserted ID within EquipWorkOrder Table
query = "SELECT top 1 EquipWorkOrderID FROM EquipWorkOrder order by DateTm desc"
results = system.db.runQuery(query)
ID = results.getValueAt(0,0)
#insert data in to EquipWorkOrderHrs for Tech 1
query = "INSERT INTO EquipWorkOrderHrs(EquipWorkOrderID,UserID,Hrs) VALUES(?,?,?)"
args = [ID, event.source.parent.getComponent('Tech 1').selectedValue,event.source.parent.getComponent('Tech 1 Hrs').floatValue]
