I am getting these faults from the logs where the database faults:
java.sql.SQLException: Cannot get a connection, pool error Timeout waiting for idle object at org.apache.commons.dbcp2.PoolingDataSource.getConnection(PoolingDataSource.java:142) at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734) at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300) at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.getConnectionImpl(DatasourceManagerImpl.java:169) at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnection(DatasourceImpl.java:293) at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeToDatasource(AbstractDatasourceSink.java:165) at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeData(AbstractDatasourceSink.java:156) at com.inductiveautomation.ignition.gateway.history.sf.sinks.AggregateSink.storeData(AggregateSink.java:165) at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:147) Caused by: java.util.NoSuchElementException: Timeout waiting for idle object at org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:321) at org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:428) at org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:232) at org.apache.commons.dbcp2.PoolingDataSource.getConnection(PoolingDataSource.java:134) ... 8 common frames omitted
Sometimes I see the active connections showing 8/8.
I wanna try to catch what’s happening (either from MS SQL or Ignition), if the db is getting slower or I’m actually having a heavier load and more queries.
