Hi All,
i have problem with Database query
How to use Database JSON default function in Ignition, for example in SQLite, we can query JSON data with JSON_EXTRACT(data, '$'), but when i apply it in DB Browser or Scripting, it will return 0.0
Hi All,
I believe since Ignition is using JBDC drivers for sql, they cannot return complex types. For example you can't return a type of uuid[] in postgresql you instead have to convert it to a string and then manipulate the data with scripting. So if you attempt to return data as a string in your SQLExpress using either cast or convert. and then utilize python for converting back to json and getting data out that way.
I have tried something like this on SQLite
| id | json_column |
| 1 | NULL |
| 2 | NULL |
| 3 | [{"name": "jhon", "age": 40}] |
SELECT JSON_EXTRACT(json_column, '$') AS jsonData FROM table WHERE id = 3
its working.
But when i query :
the json data that has id=3 become 0
When you just query [json_column] what do you get?
OK i think i got it working,
i need to handle the NULL value which is not JSON valid format
so what i did was
SELECT
CASE WHEN json_column IS NULL
THEN "NULL"
ELSE JSON_EXTRACT(json_column, '$')
END AS json_data
FROM table
Thanks @Benjamin_Furlani
Perfect! Glad you got it working
