Database related
Hello,
I am connecting 28 machines to the ignition over Modbus TCP/IP & using MySQL database for the historian database. Now I am finding difficulty to show the alarms status/analysis on the respective dashboard for the respective machine.
Can you please help me to resolve the problem? How can I show the respective machine alarm on the respective dashboard in perspective?
Thanks,
Bharat Vinchwekar
How did you organize your tags? Hopefully with folders/names that correspond to your machines. Then your default "Display Path" for alarms will contain a filterable value for your alarm display/journal components.
Yes excatly like you said...
I will check as you said
Thanks Phil
