Database Source Not Found
I have been breaking my head over this for a couple of hours now and I can't figure out what is wrong with this I am trying to make a simple db update query but I keep getting an error everytime I run it this is the script:
def runAction(self, event):
	# Define the query with placeholders
	queryName = "UPDATE levelChecker SET width = '5.6' WHERE IDValue = 'A55638U89'"
	# Define the arguments as a list
	#args = [self.view.params.Value]
	databaseName = "DBSecondaryConnection"
	# Run the query and get the number of rows affected
	rows = system.db.runUpdateQuery(query = queryName, database = databaseName, tx = 5000)
and here is the error:
	Error running action 'dom.onClick' on screens/popups/databaseEditorPopup@6n8lW90/root/FlexContainer_0/Button: Traceback (most recent call last): File "<function:runAction>", line 11, in runAction at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:188) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery(UPDATE levelChecker SET width = '5.6' WHERE IDValue = 'A55638U89', Transaction datasource unknown, 5000, false)
I looked up the error and it is saying it is related to the fact that the database connection doesn't exist. But I doublechecked the name and even did a script to get the name of it. i am also pulling information and inputting information to it from transaction groups and tag queries. I am doing in it scripting because eventually this script needs be dynamic where the table name, column and IDValue change. Anyone have any ideas on why this isn't working?
Consider setting up a Named Query. They allow you to specify the database connection and tests the query aswell. The its as simple as running the system.db.runNamedQuery() function.
You're providing a tx, which expects a transaction id. Where does it come from ? you're passing 5000, which doesn't look like a transaction id to me, more like a timeout delay.
If you did mean to supply a transaction id, make sure it's correct and the transaction is opened.
Otherwise, remove that parameter.
I addition to what @pascal.fragnoud said, if for whatever reason you don't want to use a named query, and instead wish to do it all in script, then you should be using system.db.runPrepUpdate() that would look like this:
def runAction(self,event):
    query = 'UPDATE levelChecker SET width = ? WHERE IDValue = ?'
    args = [5.6,'A55638u89']
    databaseName = 'DBSecondaryConnection'
    system.db.runPrepUpdate(query,args,databaseName)
Side note: Many older IA functions do not accept keyword arguments, or don't accept them for the mandatory args. (system.db.runUpdateQuery is a very old function.) Newer functions have full support for keyword arguments, and usually say so in the documentation.
Correct me if I am wrong, but you have specified the DB name, but aren't actually calling it in the system.db call?
Nope, not wrong. Corrected code.
Ok that seemed to work thank you. However, this brings me to my next issue I want to be able to dynamically pass the column name as well. I changed my code to this but I don't get an error thrown but it also doesn't pass the update to the db:
    query = 'UPDATE levelChecker SET ? = ? WHERE IDValue = ?'
    args = [self.view.params.Column, self.getSibling("NumericEntryField").props.value, self.view.params.DPIN]
Column names aren't values. In SQL, they are part of a query's structure, which is used to prepare the execution plan. So they have to be injected into the query string itself, not passed as a parameter. Because of the high risk associated with this, you should always check such a string substitution against the known column names for a table. (Get them from your DB's information_schema if you want to automate it.)
Yes. That makes sense I had forgotten about that. Everything is working now as expected. Thank you everyone's help!
