I have a database user source that was working with no issues in the past. We moved it to a new gateway a few months ago and it still worked fine. Recently, I haven't been able to log into the designer, even though I can verify that the Database user source properties look fine and can verify my credentials on the gateway webpage (so I know my username and password are correct).
I keep getting the pesky error Login failed: Please try again.
I also verified the last time I was fixing this that the project settings point to this user source and IdP, so I'm at my wit's end as to why this doesn't work.
That was it... I missed the part where it's the Gateway AND DESIGNER security settings. Now, what's more weird is who could have changed this....
Thanks @paul-griffith!!
Hello @paul-griffith
I am facing the same issue but with the gateway login. I am not sure how can I change the settings in gateway without login.
That's not the same issue. You need to start a new thread.
You can't. You can only reset it if you've lost the password.
https://docs.inductiveautomation.com/display/DOC81/Gateway+Command-line+Utility+-+gwcmd
Thanks @Transistor. That helped me to resolve this issue.
The issue was with the user source properties.
