Hello,
I have a shared script doing a few calculations based off some named query calls (database reads).
I’m accessing the script via expression tag -> runscript. In this script, I’m also gathering some other information that I want to store to a database table every 15 minutes of the hour. This section of code will iterate and write to the database but it seems to only do it whenever it wants and not on 15 minute intervals as coded. The database write will work in the scripting console just as I want it to but not using the runscript. I’m wondering if this has something to do with scan classes? or perhaps the difference in time between the database/client/gateway? I’ve attached the write code.
**#determine if in 15 minute interval**
** currentMinute=system.date.getMinute(system.date.now())**
** if currentMinute % 15 == 0 : **
** try:**
** param4 = {“date”:spillLogTime,“sluice”:sluice,“headWater”:headWater,“gate1pos”:gate1pos,“gate2pos”:gate2pos,“gate3pos”:gate3pos,**
** “gate1boards”:gate1boards,“gate2boards”:gate2boards,“gate3boards”:gate3boards,“gen1setting”:gen1setting,“gen2setting”:gen2setting,**
** “gate1flow”:gateFlow[0],“gate2flow”:gateFlow[1],“gate3flow”:gateFlow[2],“gatesTotalFlow”:gateFlowTotal,“genTotalFlow”:combinedGenFlow,“totalFlow”:totalFlow,“site”:site} **
** q=system.db.runNamedQuery(“GBRA_Hydro_Data_Collection”,“Insert Spillway Flow”,param4)**
** except:**
** print “The Record Already exists”**
