We are seeing the below error every 30 minutes in gateway logs. We are not seeing any issues within the Audit Log, seems as if everything is getting updated fine. Also, we are using the same SQL DB connection for other tags, and we are not experiencing any connection issues. Any suggestions on troubleshooting this? I am very confident the DB connection is not lost, not sure what else would cause the Read Timeout.
DatabaseAuditProfile
"com.microsoft.sqlserver.jdbc.SQLServerException: Read timed out
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:2892)
at com.microsoft.sqlserver.jdbc.TDSChannel.read(IOBuffer.java:2029)
at com.microsoft.sqlserver.jdbc.TDSReader.readPacket(IOBuffer.java:6418)
at com.microsoft.sqlserver.jdbc.TDSCommand.startResponse(IOBuffer.java:7579)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:590)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:522)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7194)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2935)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:248)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:223)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:471)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:1015)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepUpdate(SRConnectionWrapper.java:182)
at com.inductiveautomation.ignition.gateway.audit.DatasourceAuditProfile.prune(DatasourceAuditProfile.java:293)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:565)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(Unknown Source)
at java.base/java.net.SocketInputStream.read(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSChannel.read(IOBuffer.java:2023)
… 21 common frames omitted
