Dataset bound Dropdown
I have a Dropdown that is bound to a two column dataset. Currently it only shows data from one column. How can I show both column with a space in between?
You’d need to transform the binding being used.
The following code assumes the 0th column contains my “value” and the 1th column contains the “label”
	options = []
	for i in range(0, value.getRowCount()):
		option_val = value.getValueAt(i, 0)
		option_label = str(option_val) + " " + str(value.getValueAt(i, 1))
		options.append({"value": option_val, "label": option_label})
	return options
