Dataset Conversion
Hello There,
I have a lisf of tuples that I want to convert into dataset.
[('Test Time', '3.00'), ('Test Temp', '145.00'), ('Torque Range', '8.0'), ('I-Filter', '6.00'), ('ML', '2.24'), ('MH', '5.80'), ('TS2 dNm', '0.63'), ('T10', '0.38'), ('T50', '0.59'), ('T90', '0.94'), ('Max Rate', '7.05'), ('TS1 dNm', '0.48'), ('tanD@MH', '0.308'), ('tanD@ML', '0.571'), ('T25', '0.46'), ('T30', '0.49'), ('crazy result', '10.27'), ('T40', '0.54'), ('T60', '0.66'), ('TC90-TC10', '0.57')]
Looking for something 1 or 2 liner code.
With the above as tlist, yielding one row with column headings:
return system.dataset.toDataSet([x[0] for x in tlist], [[x[1] for x in tlist]])
Worked…!!!
Thank you
