Here’s the basic code I have setup, I’m sorting datasets based on the criteria that they have a certain number of rows. But, the get.rowCount() function isn’t returning an integer?
for i in range(len(noteList)):
for header in headerList[1:]:
path = str(noteList[i]) + "/" + str(header)
param = system.tag.read(path).value
if param is not None:
if param.getRowCount > 0:
newSet.append(path)
The script console in the designer says something about a bound method, and is printing out this:
15:32:29.776 [Browser Events Thread] INFO Perspective.Designer.BrowserConsole - <bound method com.inductiveautomation.ignition.common.BasicDataset.getRowCount of Dataset [0R ? 4C]>
