Hi, I am new to ignition and i am experimenting with the report module. I want to print a PDF with a table containing information given by the user. So far I have been able to get the information on the table in Vision and move it to the report on a Dataset parameter, but when I try to put the dataset on de design section and save the PDF it does not appear as the table but as a list like this [Column1=11; Column2=12;] instead of a table similar to how it looks on the Vision section.
I checked the video tutorials and the documentation about tables but it does not give an idea on how I can go from the dataset parameter to a proper table that I can put on the pdf and putting the dataset as Data Key did not do anything.
Thank you in advance for the help.
