DataSet Parameter in Java
Hello, i want to add a “DataSet” parameter inside my component. I didn’t know wich type of variable I need to declare for the “DataSet” in my java class. By exemple, their is a DataSet parameter in the Pie Chart object of Ignition Designer.
I’m adding the parameter with :
[code]public [Type of Variable] Data;
getData()
setData(…)
addProp(“data”, “Data”, “”, CAT_DATA); //into CommonBeanInfo[/code]
Thanks !
The datatype is just called Dataset. Just use:
import com.inductiveautomation.ignition.common.Dataset;
It works, thanks
