Dataset row value changes as data is added
Hello all,
I have this application where data is updated on the text label on the screen as operator scans new parts for a stack of 8. Currently, each label has a 1 sec polling named query and I have 25-30 such screens with about 10 queries per screen which seems to be pushing limits.
I came up with a named query with several select statements with an UNION binded to a custom prop.
Select COALESCE(SUM(serial), 0) from parts where layer = :layer and layer_pos = :layer_pos and pallet = :pallet and stack_pos = 1
UNION
Select COALESCE(sum(serial), 0) from parts where layer = :layer and layer_pos = :layer_pos and pallet = :pallet and stack_pos = 2
UNION
etc..up to stack_pos=8
Say the first part is 1 and gets into Dataset[1,0]. When I scan the second part, the first part number gets moved to Dataset[2,0] and so on getting pushed down in the dataset table.
In the following, last 3 digits '492' was the first scan and it started at [1,0] and is now at [3,0]
Any suggestions on how to make it stay at [1,0] because that's what the label refers to?
TIA.
Why are you using a DB for this? Just scan into UI custom properties as your operator builds their "stack", then write it all to the DB at the end.
This is already an existing system, and I am also new to Ignition. Also, they have other functions on the screen like deleting, updating position etc where they needed direct DB access.
For now, I am trying to optimize without rewriting much as more perspective sessions like this are being added causing more congestions.
In that case, I would recommend (assuming you really need all the stack positions):
  • Creating a table that holds all possible stack positions.
  • Use a left join / subquery to return all rows of the pallet, whether a serial exists for it or not.
  • Use a lookup() expression on the label to point to the correct row in the dataset.
SQLFiddle example here:
Thanks Jordan.
I did exactly the same yesterday. Returning stack pos with serial from the database into dataset and used lookup function to populate serial based on stack pos.
I logged in today and you had the same thing :slight_smile:
