I just wanted to check if I was missing something, Is there a way to bind a single cell of a memory dataset tag to a component like a label?
The way I’m doing it works but is pretty long-winded and I’m having to do it a lot:
- create custom property that reads the value I want from the dataset
- bind the property I want (text for a label) to it
- create script that checks for the right property change, and that the new value is different from the custom property
- re-writes the dataset with the new value
I understand datasets are immutable, but being able to bind directly to an address of a dataset tag should be the real advantage of using those types of tags
