Is it possible to use a dataset tag to populate the value of a label instead of using a switch statement?
For instance i create a dataset tag with value,label columns. can i bind the label value to the selected value of another tag or am i better off using a multi-state indicator
How did i miss that,
thank you .
An example can be found here:
