Good Afternoon.
I have updated from Ignition 7.9.9 to Ignition 8.0.6 and I have noticed that some properties of the tags of the DataTypes are empty and some instances are created as folders.
For example: “Moldeadora” is a DataType and “Estado” is an instance of another DataType (“Maquina_Estado”). As you can see in the image, in Ignition 7, the “OPC item Path” of the tag “Comunicando_Intranet” is filled, but in Ignition 8 it is empty:
Ignition 7:
Ignition 8:
Other example: “Moldeadora_Alarmas” is a DataType and “Alarma_001” is an instance of another DataType (“Moldeadora_Alarma”). As you can see in the image, in Ignition 7, the “Value” of the tag “Descripcion_Alarma” is filled, but in Ignition 8 it is empty:
Ignition 7:
Ignition 8:
Another problem: Some instances of DataTypes are created as folders in Ignition 8. For example, “Alarma_009” is an instance of “Moldeadora_Alarma”, but it appears as a folder:
Ignition 7:
Ignition 8:
Best Regards.
