I found a lot of posts here showing datetime operations but I just can’t get this working. I’ve got two memory tags and they both contain DateTime objects. I store the “start time” after the user toggles a button, then I add some random numbers to that date/time to create an “end time” (no apocalypse jokes, please). I then want to subtract the two using a repeating timer to show a countdown.
This is all done in a gateway script, BTW. Know there’s probably a simple answer but I don’t see it. I have not used strptime() to perform any formatting, either. I figure because both startTime and nextTime are the same format it does not need it.
This will calculate the difference between your two tags - startTime = system.tag.read("Test_StartDate").value
endTime = system.tag.read("Test_EndDate").value
timeDiff = endTime.getTime() - startTime.getTime()
timeDiffSeconds = timeDiff / 1000
timeDiffMinutes = timeDiff / (60 * 1000)
timeDiffHours = timeDiff / (60 * 60 * 1000)
timeDiffDays = timeDiff / (24 * 60 * 60 * 1000)
But your timeDiff value will always be the same unless your startTime or endTime values are changing. If you’re just looking to display a time difference to the user then it might be easier to use the Expression Function dateDiff on a property binding.
Thanks, but could not get that to work. I added from java.util import Calendar and used getInstance() for the start, end and countdown dateTimes. After publishing, the gateway console error is Traceback (most recent call last):
File "<TimerScript:Company_ABC/Random Number Generator @10,000ms >", line 27, in <module>
TypeError: setTime(): 1st arg can't be coerced to java.util.DateIf I can’t get this working I’m going to take your advise and try an Expression Tag because it seems like it’s pretty difficult to subtract two dateTimes using a script.
[quote=“Pat”]I’m using version 7.8 and for some reason I don’t need to import the java Date class in order for .getTime() to work, not sure why though.[/quote]That’s true in general in jython/python. You don’t need to import a data type for objects you already have. You need to import to access constructors and static methods and class constants.
Also, since jython operates with the NetBeans specification, these statements:current = obj.getSomething()
object.setSomething(newval)can instead be written as:current = obj.something
obj.something = newvalSo .getTime() is also just .time
So, the delta time can be obtained like so:startTime = system.tag.read("Test_StartDate").value
deltaMillis = endTime.time - startTime.time
Thanks, guys, appreciate all the input. I scrapped my original plan and used Al’s Java-based routine instead. It only seems to give me an integer of the time (wanted the date, too) but it works. I now get a little countdown timer that can be bound to a progress bar.
