Date conversion- String to Datetime
Hi guys,
I'm trying to convert the string date to DateTime format following the way:
Insert date from power table to database.
Date = dsData.getValueAt(rowIndex,'Date')
date = system.date.parse(Date, "yyyy-MM-dd  hh:mm:ss.SSS")
Got error
Required this format (database format):
Ignition - 8.1.17
SQL Server 16
Any suggestion?
Thanks,
Priyanka
the format string in system.date.parse() requies it to match the format of the string coming in.
date = system.date.parse(Date, 'dd.MM.yyyy')
@JordanCClark Thank you so much.
Work perfectly!!
