hi Team,
i am trying get the data from SQL table to Perspective Table component, but dat format is displaying as string format, that i couldn't able to solve this.
- In
props.columnshit the + button and add in as many columns as you want to display. - In each of those edit the
fieldvalue to the name of the SQL column. - For date display set the column's render to
date.
hi,
so i have almost 9 columns from the SQL table, you mean i have to add all 9 columns in the prop.column field??
Yes, if you want full control of them.
okay!! let me try.
Thanks Any way for the timely response ![]()
In your SQL query, replace the datetime columns with this:
from_unixtime(column_name / 1000) or the equivalent for your database.
edit: Actually, don't. It's probably better to let the table handle the display format... Configure your columns as @Transistor said.
WORKING!!
Thanks ![]()
