Date format string
In alarm table component, property format string, the manual says that living blank the locale will be used. Very logical.
Indeed in the designer I'm not able to leave blank because also editing a pre-formatted table is provided. No opportunity to leave blank.
The issue is that at runtime, always the format string indicated is used. I can bind/script, but why is not possible to leave blank and using the locale at runtime?
below is the date format option for the alarm status component... it defaults to blank so you would just need to not put anything in here, or simply select the format entered and then hit the backspace key on your keyboard to clear it.
It works, also binding an empty string the Client is using the locale.
Thx.
