The script below is being used to set up a database connection based on a selected date on a calendar object. The comparison between the dates is not evaluating the same every time it runs and is often evaluating incorrectly.
The print statements are for my debug efforts.
Is there something I am doing wrong?
[code]if event.propertyName == “date”:
print event.propertyName
from java.util import Calendar
cal = Calendar.getInstance()
cal.add(Calendar.DAY_OF_YEAR, -2)
olddate = cal.getTime()
date = event.source.date
print olddate
print date
if date < olddate:
print "Archive"
event.source.parent.getComponent('Label 10').text = "Archive"
event.source.parent.getComponent('PassData').Database = 'L_PROC_DATA'
event.source.parent.getComponent('PassData').TableName = 'COIL_PROC_SUMMARY'
else:
print "Active"
event.source.parent.getComponent('Label 10').text = "Active"
event.source.parent.getComponent('PassData').Database = 'Tmill'
event.source.parent.getComponent('PassData').TableName = 'RTM_COIL_HSIO_SUM'[/code]
Thank you,
Pat
