Date intervals spanning across days
Hello I have this code -
# Function to create SampleEvent entries
def create_sample_events(data):
	# current_Ttime
	current_time = datetime.datetime.now()
	# Get IDs for ProductionEvent, ProductSample, Product, Sample, SampleSchedule for each row
	for row in data:
	    pe_id = row['ProductionEventID']
	    ps_id = row['ProductSampleID']
	    p_id = row['ProductID']
	    s_id = row['SampleID']
	    ss_id = row['SampleScheduleID']
	    # Get the time for last sample taken for that ProductionEvent
	    last_sample_time_dataset = system.db.runNamedQuery("Scheduling/GetLastSampleEventTime",parameters={"productionEventID": pe_id})
	    last_sample_time = last_sample_time_dataset.getValueAt(0, 0)
	    # Get Interval and Offset for the SampleSchedule
	    intervalOffset = system.db.runNamedQuery("Scheduling/GetIntervalOffsetBySampleScheduleID",parameters = {"sampleScheduleID": ss_id})
	    # Get Interval value
	    sample_interval = intervalOffset.getValueAt(0,"Interval")
		# If there is no last_sample_time use offset
	    if last_sample_time == None:
	    		print("No last")
	    # If there is a last_sample_time
	    else:
	    	# Calculate the next_sample_time by adding the interval to the last_sample_time
	    	next_sample_time = system.date.addHours(last_sample_time, sample_interval)
I am running into an issue where if the last_sample_time takes place a day(s) before. The next sample_time will be set to day(s) earlier than it should be. I want the next_sample_time to be the last_sample_time but for the current date (or potentially the day after).
Update: could potentially just get the minutes between last_sample_time and current time and add that to the last_sample_time + interval ??
It's there still a question here, or was this question answered sufficiently by this post?
It was answered sufficiently in that post.
