I am trying to set a range on this component using strings I have for the current date {date} and a string that represents a time.
Start date is bound to the expression:
toDate({Root Container.Date} + right({Root Container.Start},8))
where a string (Date):
dateFormat(now(),"MM/dd/yyyy ")
and a string (Start):
SELECT Starttime FROM Shifts WHERE Shiftname = '{Root Container.GroupName.selectedStringValue}'
I keep getting errors that look like:
Exception: Error executing expression binding on
ShiftReport.Root Container.Date Range.startDate
caused by ExpressionException: Unable to cast value: ‘05/24/2013 09:00 AM’ to a(n) Date. Try using a failover parameter in your cast function.
Ignition v7.6.0 (b1875)
Java: Sun Microsystems Inc. 1.6.0_45
Can someone point out my mis step?
