Ign 7.7.0 (b2014071516) | 64-bit
I have an issue using dateFormat in a textbox.text field
Here is an example that you can reproduce
This works
dateFormat({[System]Client/System/CurrentDateTime},{[System]Client/System/CurrentDateTime.FormatString})
This does not
dateFormat(tag("[System]Client/System/CurrentDateTime"),{[System]Client/System/CurrentDateTime.FormatString})
Type mismatch, arg 0 error invalid type
But
displays date text ok.
It appears the tag() returns the date value as a string. dateFormat() requires it to be a date.
Try dateFormat(toDate(tag("[System]Client/System/CurrentDateTime")),{[System]Client/System/CurrentDateTime.FormatString})
I also had to do a toStr on the formatstring.
Does this mean the tag call is returning the object repr rather than object.value? One would not expect to have to cast a string object.
My real example uses MES production model tags and this finally appears to work.
if (isNull(tag({[Client]MES/Selections/selectedLineTagPath}+"/Actual Start Time")),"",
dateFormat(toDate(tag({[Client]MES/Selections/selectedLineTagPath}+"/Actual Start Time")),
toStr(tag({[Client]MES/Selections/selectedLineTagPath}+"/Actual Start Time.FormatString"))))
