Datetime formatting issue on APEX charts for .CSV downloads
I’m facing an issue with the APEX Line Chart (V1.0.18) regarding data export. Despite configuring the categoryFormatter option as per the APEX documentation, the exported .csv file does not reflect the desired date format.
Current Export Format: Dates are formatted using .toDateString() (e.g., Tue Nov 26 2024).
Expected Export Format: I need the format dd/mm/yyyy HH:mm:ss in the .csv file.
Configured categoryFormatter in the chart options to format the date as dd/mm/yyyy HH:mm:ss.
{return new Date(x).toLocaleTimeString()}
or
{return new Date(x).toLocaleDateString()}
However, the .csv export still defaults to .toDateString()
The apex docs show that the translation expects a function.
The module docs says you have to define a function like this. so you will need to do it like that.
(If this is the module you are using ofc)
Thanks for the docs but unfortunately it is not working.
show me how you setup the function
I tried to format the Y value to check whether the function is working.
It seems you are misunderstanding what is happening.
The docs ofc the perspective module showed only a sample. The fuction in the does not work on a different property.
for your csv properties the function should probably follow this:
valueFormatter : function (y) { return y }
categoryFormatter: function (x) { return new Date(x).toDateString() }
However note that for dates this might be different, since it seems igntion might send the formated date as X which might need a more elaborate new Date function to parse the string to a valid date object.
For debugging purposes i wonder if you see something inthe inspector log in the browser if you put in some logging.
categoryFormatter: function (x) { console.log(x); return new Date(x).toDateString() }
disclaimer i dont have the module, but i know something about javascript:)
Tried this: valueFormatter: function (y) { return y; }, categoryFormatter: function (x) { return new Date(x).toDateString(); } earlier, but Apex is not picking up the configs, and the console.logs function (x) { console.log(x); return new Date(x).toDateString() } are not getting generated.
than you will have to contact the module maker
if anyone else is having this problem:
set the options.chart.toolbar.export.csv.categoryFormatter to a JavaScript function:
 function (x) {
    return new Date(x).toISOString().replace('T', ' ').slice(0, -1);
you'll get a csv like :
you can also use toLocaleString for the users time zone:
function (x) {
    return new Date(x).toLocaleString()
it should look something like this in your designer:
finally, if you want to avoid commas in your timestamp you can do like
function (x) {
    return new Date(x).toLocaleString(undefined, { hour12: false }).replace(/,/g, '');
