Datetime Input doesn't update selected date after reopening view
Hello,
I use DateTime input component in a dock view. At first time I open dock view the props.value = null and picking date is work as expected.
After closing and re-opening dock view the DateTime input component has its last selected value but if i want to select a new daye and time again, that doesn’t work. even I can’t change the time and min entries.
For clearance I take a video. At first time it works and opening dock again it doen’t.
https:/uploads/iatesting/original/2X/d/dbd220fb5bd850c8f348058e5708bbb50b2c3111.mp4
I noticed the same strange behavior.
I am currently working on a 8.0.5 gateway.
It is very annoying :no_mouth:
Thank you.
I also try it on 8.0.7 and 8.0.6.
I wonder why none from IA confirm it and make a ticket for it.
Because they might not have noticed this forum post. This forum is not official support. Open a ticket at support.inductiveautomation.com for actual, official support.
@nader.chinichian Did you go forward on posting this issue in the support portal?
If not, I can do it in order to solve the problem asap.
Thank you.
Andrea
Yes I did this yesterday.
Please forward this bug to support too. If so many people request it it may fix sooner
I did it as well today.
Hi every one,
Did you solve this issue? I have Ignition 8.0.9 and I have the same problem, and it also ocurrs with dropdown list components.
Thank you.
Yes I test it in 8.0.10 and it work as it should be.
Thanks for the respose. Did you do any special configuration? I recently update from 8.0.9 to 8.0.10 to solve other issue for auto range in time series chart, but I got the same error. Dates revert to the state saved in the designer.
No nothing just in designer leave the date picker empty and let user change it.
