Hi there,
Is it possible to have in run time, when click inside component, the same selection input value window used in edition for properties minDate/maxDate in edition, with 'Ok' and 'Cancel' buttons ?
Something didn't translate very well here!
Can you explain a bit more how you would like it to work?
There is no configuration for the component to include those buttons. The only way to manage something similar would be to create your own Popup with a DateTime Picker in date mode, and with your own buttons to control the logic of confirming the value.
I will do like this, tank you.
