DB based Trends
Hello Everybody,
I need a help with trends in perspective 8.1.36
I have a database table as shown below consisting of three columns, Timestamp, Counts & Roll ID, I would like to show the counts for in Roll ID based on time selected using this table.
As new RolID gets logged in table it should dynamically add them in Chart PROPS and shown the new trends (if it fits the time scale selection).
DB used is PostgreSQL
Any help/guidance or point to right direction would be helpful, Thanks !
That's going to be a bit of work.
I suggest that you use an XY Chart.
  • Get the data in JSON format. It should be something like this:
	{'t_stamp': '2024-03-06 16:47', 'Roll 1': 1},
	{'t_stamp': '2024-03-06 17:02', 'Roll 1': 2},
	{'t_stamp': '2024-03-06 17:19', 'Roll 1': 3},
	{'t_stamp': '2024-03-06 18:00', 'Roll 1': 4},
	{'t_stamp': '2024-03-06 18:24', 'Roll 1': 5},
	{'t_stamp': '2024-03-06 18:43', 'Roll 1': 6},
	{'t_stamp': '2024-03-06 19:04', 'Roll 1': 7},
	{'t_stamp': '2024-03-06 19:20', 'Roll 1': 8},
	{'t_stamp': '2024-03-06 20:01', 'Roll 2': 1},
	{'t_stamp': '2024-03-06 20:41', 'Roll 2': 2},
	{'t_stamp': '2024-03-06 21:19', 'Roll 2': 3},
	{'t_stamp': '2024-03-06 21:41', 'Roll 2': 4},
	{'t_stamp': '2024-03-06 22:03', 'Roll 2': 5},
	{'t_stamp': '2024-03-06 22:46', 'Roll 2': 6},
	{'t_stamp': '2024-03-06 23:26', 'Roll 2': 7},
	{'t_stamp': '2024-03-06 23:55', 'Roll 3': 1},
	{'t_stamp': '2024-03-07 00:16', 'Roll 3': 2},
	{'t_stamp': '2024-03-07 00:44', 'Roll 3': 3},
	{'t_stamp': '2024-03-07 01:09', 'Roll 3': 4}
Note that I've added the word "Roll " into the Roll column to help with identification in the chart. You can paste this in as a new datasource for experimentation.
  • You'll need to script the series to generate a series for each roll. That may require a query of the form,
    SELECT UNIQUE CONCAT("Roll ", RollID) FROM ...
Try pasting this into an empty view.
Roll XY Chart
    "type": "ia.chart.xy",
    "version": 0,
    "props": {
      "xAxes": [
          "name": "time",
          "label": {
            "enabled": true,
            "text": "Time",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": "",
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
              "skipEmptyPeriods": false
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "yyyy-M-d HH:mm",
            "format": "HH:mm"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "logarithmic": false,
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
            "format": "#,###.##"
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
              "verticalCenter": "middle",
              "horizontalCenter": "middle"
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": 60,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
          "appearance": {
            "font": {
              "size": "",
              "weight": 500
            "grid": {
              "color": "",
              "dashArray": "4,4",
              "minDistance": null,
              "opacity": 1,
              "position": 0.5
            "inside": false,
            "labels": {
              "color": "",
              "horizontalCenter": "middle",
              "opacity": 1,
              "rotation": 0,
            "opposite": false
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05,
              "startCategory": ""
          "date": {
            "baseInterval": {
              "count": 1,
              "enabled": false,
              "skipEmptyPeriods": false,
              "timeUnit": "hour"
            "break": {
              "enabled": false,
              "endDate": "",
              "size": 0.05,
              "startDate": ""
            "format": "M/d/yyyy",
            "inputFormat": "yyyy-MM-dd kk:mm:ss",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "inversed": false,
          "label": {
            "color": "",
            "enabled": true,
            "text": "Count"
          "name": "count",
          "render": "value",
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": ""
          "value": {
            "break": {
              "enabled": false,
              "endValue": 100,
              "size": 0.05,
              "startValue": 0
            "format": "#,###.##",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "visible": true
      "series": [
          "name": "Roll 1",
          "label": {
            "text": "Roll 1"
          "visible": true,
          "hiddenInLegend": false,
          "defaultState": {
            "visible": true
          "data": {
            "source": "rollData",
            "x": "t_stamp",
            "y": "Roll 1"
          "xAxis": "time",
          "yAxis": "count",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "{name}: [bold]{valueY}[/]",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "deriveFieldsFromData": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "green",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "name": "Roll 2",
          "label": {
            "text": "Roll 2"
          "visible": true,
          "defaultState": {
            "visible": true
          "data": {
            "x": "t_stamp",
            "y": "Roll 2"
          "xAxis": "time",
          "yAxis": "count",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "green",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "#1AC218",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "name": "Roll 3",
          "label": {
            "text": "Roll 3"
          "visible": true,
          "defaultState": {
            "visible": true
          "data": {
            "x": "t_stamp",
            "y": "Roll 3"
          "xAxis": "time",
          "yAxis": "count",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "green",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "#D7221A",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
      "dataSources": {
        "rollData": [
            "t_stamp": "2024-03-06 16:47",
            "Roll 1": 1
            "t_stamp": "2024-03-06 17:02",
            "Roll 1": 2
            "t_stamp": "2024-03-06 17:19",
            "Roll 1": 3
            "t_stamp": "2024-03-06 18:00",
            "Roll 1": 4
            "t_stamp": "2024-03-06 18:24",
            "Roll 1": 5
            "t_stamp": "2024-03-06 18:43",
            "Roll 1": 6
            "t_stamp": "2024-03-06 19:04",
            "Roll 1": 7
            "t_stamp": "2024-03-06 19:20",
            "Roll 1": 8
            "t_stamp": "2024-03-06 20:01",
            "Roll 2": 1
            "t_stamp": "2024-03-06 20:41",
            "Roll 2": 2
            "t_stamp": "2024-03-06 21:19",
            "Roll 2": 3
            "t_stamp": "2024-03-06 21:41",
            "Roll 2": 4
            "t_stamp": "2024-03-06 22:03",
            "Roll 2": 5
            "t_stamp": "2024-03-06 22:46",
            "Roll 2": 6
            "t_stamp": "2024-03-06 23:26",
            "Roll 2": 7
            "t_stamp": "2024-03-06 23:55",
            "Roll 3": 1
            "t_stamp": "2024-03-07 00:16",
            "Roll 3": 2
            "t_stamp": "2024-03-07 00:44",
            "Roll 3": 3
            "t_stamp": "2024-03-07 01:09",
            "Roll 3": 4
    "meta": {
      "name": "XYChart"
    "position": {
      "basis": "476px"
    "custom": {
      "sqlResult": [
          "t_stamp": 1709743620000,
          "Count": 1,
          "RollID": "Roll 1"
          "t_stamp": 1709746096701,
          "Count": 2,
          "RollID": "Roll 1"
          "t_stamp": 1709748766661,
          "Count": 3,
          "RollID": "Roll 1"
          "t_stamp": 1709749919414,
          "Count": 4,
          "RollID": "Roll 1"
          "t_stamp": 1709750892807,
          "Count": 5,
          "RollID": "Roll 1"
          "t_stamp": 1709752423674,
          "Count": 6,
          "RollID": "Roll 1"
          "t_stamp": 1709755034731,
          "Count": 7,
          "RollID": "Roll 1"
          "t_stamp": 1709756487570,
          "Count": 8,
          "RollID": "Roll 1"
          "t_stamp": 1709758071533,
          "Count": 9,
          "RollID": "Roll 2"
          "t_stamp": 1709760770040,
          "Count": 10,
          "RollID": "Roll 2"
          "t_stamp": 1709762054662,
          "Count": 11,
          "RollID": "Roll 2"
          "t_stamp": 1709763717697,
          "Count": 1,
          "RollID": "Roll 2"
          "t_stamp": 1709766197577,
          "Count": 2,
          "RollID": "Roll 2"
          "t_stamp": 1709767188908,
          "Count": 3,
          "RollID": "Roll 2"
          "t_stamp": 1709769054979,
          "Count": 4,
          "RollID": "Roll 2"
          "t_stamp": 1709771292439,
          "Count": 5,
          "RollID": "Roll 3"
          "t_stamp": 1709773497640,
          "Count": 6,
          "RollID": "Roll 3"
          "t_stamp": 1709774987668,
          "Count": 7,
          "RollID": "Roll 3"
          "t_stamp": 1709776905435,
          "Count": 8,
          "RollID": "Roll 3"
Consider using the "DB Table History Provider" to just drop these into a PowerChart.
Thanks ! Will try.
Thanks @pturmel , but wouldn't it require each Roll ID have separate column to show individual trends ?
No, you can use a key to segregate trends in the same table.
Thank you @pturmel I managed to achieve my objective
First I created a Query tag - 1 sec poll and retrieved a RollID column as Dataset and then used that in below code to loop through and append Pen PROP on Power chart.
	Value = system.tag.readBlocking('[default]Enterprise/New Tag 1')[0].value
	RollID = ''
	pens = []
	for row in range(Value.getRowCount()):
	    for col in range(Value.getColumnCount()):
	        RollID = Value.getValueAt(row, col)
	        tagPath ='histprov:Valve Consumption:/table:"Consumption":/column:Count:/timestamp:TimeStamp:/keycolumn:RollID:/keyvalue:' + str(RollID)
	        pens.append(
						    "name": str(RollID), #name,
						    "visible": True,
						    "enabled": True,
						    "selectable": True,
						    "axis": "Axis 1",
						    "plot": 0,
						    "display": {
						      "type": "line",
						      "interpolation": "curveLinear",
						      "breakLine": True,
						      "radius": 3,
						      "styles": {
						        "normal": {
						          "stroke": {
						            "color": "#DE7E41",
						            "width": 1,
						            "opacity": 0.8,
						            "dashArray": 0
						          "fill": {
						            "color": "#DE7E41",
						            "opacity": 0.8
						        "highlighted": {
						          "stroke": {
						            "color": "#DE7E41",
						            "width": 1,
						            "opacity": 1,
						            "dashArray": 0
						          "fill": {
						            "color": "#DE7E41",
						            "opacity": 1
						        "selected": {
						          "stroke": {
						            "color": "#DE7E41",
						            "width": 1,
						            "opacity": 1,
						            "dashArray": 0
						          "fill": {
						            "color": "#DE7E41",
						            "opacity": 1
						        "muted": {
						          "stroke": {
						            "color": "#DE7E41",
						            "width": 1,
						            "opacity": 0.4,
						            "dashArray": 0
						          "fill": {
						            "color": "#DE7E41",
						            "opacity": 0.4
						    "data": {
						      "source": tagPath,
						      "aggregateMode": "Average"
		self.getSibling("PowerChart").props.pens = pens
