DB Driver JAR File Location
Is it possible that the docker image for 8.1.43 recently changed such that my Oracle DB driver must now be found here?
/usr/local/bin/ignition/user-lib/jdbc
and not here:
/usr/local/bin/ignition/user-lib/jdbc-bundled
For Ignition 8.1.x, you can place your database driver JAR's directly into place under ${IGNITION_INSTALL_LOCATION}/user-lib/jdbc. The technique used for this can vary based on your needs; some examples might be:
  • building a derived image
  • bind-mounting files directly
  • mapping a volume to this folder (with this, you're locking in the versions of JDBC JARs, similar to what is done with a traditional installation).
The location has not changed across Ignition 8.1.x.
Ignition on Docker, unless so configured (using one of the techniques mentioned above), will use the built-in JDBC JARs to the latest versions (from the image).
On a standard installation, upgrades leave your existing JDBC JARs in place. The .../user-lib/jdbc-bundled folder of a normal installation is where Installer places updated distributions of the JARs that Ignition ships with. They're here for reference only, and not loaded by Ignition.
I'll note that we've improved this "wrinkle" with the upcoming Ignition 8.3.0. In there, JDBC drivers will be defined (JARs and their associated database driver configuration JSON) in the configuration stored in the data volume. You'll no longer have to take specialized actions in your Docker container configuration to persist additional JAR files.
Let me know if I can help further with any challenges you're having.
Actually, retracting my solution because I have a dozen or so containers that for, the past several months have been loading the JAR from a jdbc-bundled mapped vol. And then all of a sudden, the mapped vol needs to be just jdbc.
I can assert that JARs have never loaded from jdbc-bundled. Is it possible that you launched the containers, installed the JARs through the web UI and ran them that way for some time? If you only stopped/started the containers, everything might be fine until you recreated the container (such as for upgrading to a newer version). At that time, the user-lib/jdbc folder would revert to that from the image and you might end up in that situation. The correct fix (all along) is to persist user-lib/jdbc in order to have files there live across container lifecycle events.
Hmmm ... strange. I have personally downed these containers, with volumes and purged unused vols many, many times; I think everything but pull a new image.
they all have
 volumes:
    ./third-party-modules/drivers/oracle-jdbc11.jar:/usr/local/bin/ignition/user-lib/jdbc-bundled/oracle-jdbc11.jar
But now no bueno.
I tried loading the driver through the web interface as well (this how I figured out where it's happiest), and it did not survive even container restarts.
The only other thing I can think of is that GWBK restore will populate the user-lib/jdbc folder with files from the backup (if present). If you're always seeding these containers from a GWBK, that could explain the behavior (until now, perhaps when your GWBK might not already contain your oracle JDBC JAR).
Yea, I think that might explain things.
From a container where this is not an issue:
root@1B-EPMS1:/usr/local/bin/ignition# cd user-lib/
root@1B-EPMS1:/usr/local/bin/ignition/user-lib# ll
total 56
drwxr-xr-x 1 ignition ignition  4096 Jun  5 19:34 ./
drwxr-xr-x 1 ignition ignition  4096 Jun  5 19:33 ../
drwxr-xr-x 3 ignition ignition  4096 Jun  5 19:34 cls/
drwxr-xr-x 1 ignition ignition  4096 Jun  5 19:33 jdbc/
drwxr-xr-x 2 ignition ignition  4096 Jun  5 19:33 jdbc-bundled/
drwxr-xr-x 1 ignition ignition  4096 Jun  5 19:33 modules/
drwxr-xr-x 1 ignition ignition 12288 Jun  5 19:33 pylib/
root@1B-EPMS1:/usr/local/bin/ignition/user-lib# ll jdbc && ll jdbc-bundled/
total 10332
drwxr-xr-x 1 ignition ignition    4096 Jun  5 19:33 ./
drwxr-xr-x 1 ignition ignition    4096 Jun  5 19:34 ../
-rw-r--r-- 1 ignition ignition  207774 Aug 20  2024 commons-dbcp2-2.8.0.jar
-rw-r--r-- 1 ignition ignition  141192 Aug 20  2024 commons-pool2-2.10.0.jar
-rw-r--r-- 1 ignition ignition  621971 Jun  5 19:33 mariadb-java-client-2.7.3.jar
-rw-r--r-- 1 ignition ignition 1346940 Jun  5 19:33 mssql-jdbc-9.4.0.jre11.jar
-rw-r--r-- 1 ignition ignition 7199197 Jun  5 19:33 ojdbc11.jar
-rw-r--r-- 1 ignition ignition 1039047 Jun  5 19:33 postgresql-42.3.3.jar
total 7044
drwxr-xr-x 2 ignition ignition    4096 Jun  5 19:33 ./
-rw-rw-r-- 1 ignition ignition 7199197 Apr 29 19:28 oracle-jdbc11.jar
