DB PrepUpdate Queries?
I’m getting this error: “The conversion from UNKNOWN to UNKNOWN is unsupported.”
The documentation for SRConnection “runPrepUpdate” says the parameters are:
  1. java.lang.String query
  2. java.lang.Object… args
What is args expecting?
Assuming MSSQL driver, why does this error?
SRConnection connection = this.connection();
String query = "INSERT INTO [table] (col1, col2) VALUES (?, ?), (?, ?), (?, ?)";
List<Object> args = new ArrayList<>() {{
           add("A");
           add(LocalDateTime.now());
           add(null);
           add("C");
           add(null);
connection.runPrepUpdate(query, args); //errors here....
I figured this method is similar to system.db.runPrepUdate, right?
This is varargs syntax and you're passing it a List instead. Try an array if you can't actually expand the arguments.
Thank you! That did it.
connection.runPrepUpdate(query, args.toArray());
