DB2 Connection Error
I’m trying to create a connection to db2 but I get the following error
error%201
I tried with an as400 connection but it also fails.
https://support.inductiveautomation.com/index.php?/Knowledgebase/Article/View/120/0/connecting-to-ibm-as400-iseries-database
error%202
Does anyone have an idea why it fails?
“Obtain a licensed copy” seems pretty clear to me. You probably need to talk to IBM sales.
I also thought that, I have a valid licence and I can connect to DB using C#.Net, also using a DSN Driver
.error%203
The problem is IGNITION
ODBC != JDBC.
The JDBC driver in use is not licensed for connectivity to QDB2 databases.
You need an additional .jar file for the DB2 JDBC driver.
I’m really lost, What jar file I need?
According to the error message, db2jcc_license_cisuz.jar; which you should be able to find somewhere in your software distribution, apparently.
